What springs do i need for >.600 lift
Old Jul 5, 2005 | 06:55 PM
1BadBrd's Avatar
What spring would i need to fit a .605 lift and doesn't require maching?
Old Jul 5, 2005 | 09:03 PM
crAzy95z28's Avatar
Re: What springs do i need for >.600 lift
what mods u got to run 12.7?
i ran the same thing, but in the houston heat but my ET was 105
Old Jul 5, 2005 | 09:10 PM
Silvershark's Avatar
Hrmm... You might be able to get away with the K-800 Kmotion valve springs. Hopefully someone more knowledgable than I will chime in.
Old Jul 6, 2005 | 08:02 AM
CANTONRACER's Avatar
IMO, run a cam in the .580's, .590's range and keep it simple. Once you start playing with coil bind and installed height...heck, you might as well go bigger than .605 IMO.
Is this a hyd roller or sr?
Old Jul 6, 2005 | 06:16 PM
1BadBrd's Avatar
well the guy wants to use the k-800 motion springs, the cam is 236/242 580/605 on some 1.6RR hydroller. A good feedback from several people really like the cam. Whats the talk about the beehive springs.
I think k-800 are pushing the limit of 605 i want something a bit more reliable.
Old Jul 6, 2005 | 06:18 PM
1BadBrd's Avatar
12.7 with hotcam kit
Old Jul 6, 2005 | 07:18 PM
I am pretty sure the behives require machining. Mine are behives and they required machining.
DirtyDaveW
Mar 15, 2015 07:01 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
