what springs?
Old Jan 18, 2007 | 06:22 PM
reamo04's Avatar
what springs?
Well, its getting closer to my build and I am finalizing what I want. The cam I am going with after 1.6RRs will be around 630/615 or so lift. What springs should I use? Would the 918 beehives work?
Old Jan 18, 2007 | 08:24 PM
Gun5's Avatar
damn what cam lol any headwork??
Old Jan 18, 2007 | 09:20 PM
reamo04's Avatar
gonna be running trickflow heads, ported/polished, and either the XFI 468, or the lunati voodoo cam (60123 on summit)
Old Jan 18, 2007 | 11:24 PM
zx1216's Avatar
i think the 918 behieves are rated to .600 lift so that may be a bit extreme, they work well on my setup but i'm only at .576 for lift with my 1.6's
Old Jan 19, 2007 | 02:49 PM
SStrokerAce's Avatar
The reason I didn't post anything is because I don't think your going to get there from here boss..... XFI lobes and let me guess Scorpion Aluminum Rocker Arms? IMHO you are basically asking for the impossible.
Bret
Old Jan 19, 2007 | 03:05 PM
ABA383's Avatar
If you're not sure just get the specs needed for the springs from the company you get the cam from...
--Alan
Old Jan 19, 2007 | 06:16 PM
seawolf06's Avatar
For the voodoo cam, they recommend this:
Lunati kit #65400
Springs: 73943
The cam card says recommended install height 1.75" = 100lbs, I hope that isn't seat pressure. Seems extremely low for such an agressive cam. I think these cams were meant to be run with the stock ratio rockers.
For the xfi cam, although summit and other sites say that the lift specs are with stock rocker arms, they're actually with 1.6RR (.584/.579) I just know they're made for the 918's, but Bret Bauer and others have reservations about those on a stock displacement motor.
Old Jan 19, 2007 | 11:24 PM
reamo04's Avatar
its not a stock displacement motor, its a 383 w/ trick flow heads
Old Jan 20, 2007 | 01:15 AM
seawolf06's Avatar
Ok, that wasn't in the post, so I assumed 355. There's a guy here running that cam with 918's and getting some good results with his stroker, 396 I believe.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
