What speed do A4 cars go into 4th?
Old Apr 27, 2004 | 02:56 PM
Kataklysm's Avatar
For some reason it seems like my RPM is high at 65mph (around 2500-3000) I should probly just listen for shifts but I always forget. Anyone know what speeds the gears change?
Old Apr 27, 2004 | 03:03 PM
Ricardo's Avatar
Depends on the TPS sensor reading. Mine shows a min of 34 MPH for 0% TPS and 126 MPH for 100% TPS In normal mode
Old Apr 27, 2004 | 03:09 PM
Cmr0z28's Avatar
That's definitely way too high.....mine shifts into overdrive at 30, but I have 3.73s and a MadZ28.com PCM tune.
Old Apr 27, 2004 | 03:51 PM
Re: What speed do A4 cars go into 4th?
Give some more info, like what rear gears you have or any other pertinent modifications.
Old Apr 28, 2004 | 06:22 AM
Kataklysm's Avatar
3.23 gears, full exhaust, 160 thermostat, lt4 km.
Old Apr 28, 2004 | 12:13 PM
RPMs would be ~2750 if you were in 3rd gear at 65 mph. Sounds like you are not getting into overdrive. With light throttle, it should be easily in OD by that speed. Perhaps you should get your car scanned. You might have a tranny solenoid problem. Not all DTCs for the tranny cause the SES to illuminate. If it is shifting harder than normal, that would be an indicator of a problem as well.
Old Apr 28, 2004 | 03:00 PM
Andrew04ME's Avatar
The car im going to look at (again) today does the same thing. It'll run about 2500-3000 rpm between 65-75 at no throttle. It doesnt seem to want to go into OD. How expensive are transmission solenoid problems to fix?
Old Apr 28, 2004 | 04:36 PM
ishz28's Avatar
Not trying to hijack the tread, but I have a 3-4 upshift problem. Long story short, I changed the 3-4 upshift solenoid, fixed the problem for about a week. I've had this problem for over a year w/out it getting worse, so I figured it wasn't the clutches. What would cause this, solenoid only work for a week than problems came back?
Old Apr 28, 2004 | 07:30 PM
Kataklysm's Avatar
It goes into OD at alot higher speeds...I feel a shift at around 90mph. Is it weird that it does it at high speeds but not normal driving speeds?
Old Apr 28, 2004 | 08:57 PM
If programming was altered, it could do it at any speed it was set for.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
