What Spark Plug Should I Use?
Old Jun 5, 2009 | 02:48 PM
ENRKyle20's Avatar
I see this chart (thanks for the chart btw) but nothing really spoke to me to much. alot of decisions.
383 Stroker - LE2 Heads - LE2 Billet Cam - Pacesetter Mid Tubes - Flowmaster 80 Series Catback
11.9:1 SCR
9.1:1 DCR
93 Octaine Pump Gas (if I can pull it off)
SLP cold air intake
Aluminum elbow
Twin 58MM Profesional Products Throttle Body
Loyd Ellot Ported Intake Manifold
LE2 Heads - Comp beehive springs
LE2 billet cam
Comp Chromoly pushrods
Comp 1.6 NSA RR 7/16" Stud
LS7 Lifters
Eagle Cast Crank
Eagle Forged I Beam 5.7" Rods W/ARP Capscrews
Speed Pro Hyper -12CC Dish Forged Pistons
Stage III Clutch
Computer in car with 7" touchscreen
Widebad O2 Sensor - AFR Gauage
Thanks.
Old Jun 5, 2009 | 03:24 PM
bw_hunter's Avatar
I'd start with NGK TR6's (or equivalent) gapped at .035 and read them from there...
Old Jun 6, 2009 | 12:44 PM
ENRKyle20's Avatar
I would like to avoid ever changing the plugs in this car, or even taking them out to read them. This is the second time building this motor and Im sick of it.
im not worried about gettin an edge, using the perfect plug. I would rather just throw a plug in that will work, and work for a long time. I have pacesetter mid tubes so its nearly imposable to change the plugs with the headers on.
any suggestions? Thanks
Old Jun 6, 2009 | 01:34 PM
Stl94LT1's Avatar
NGK makes an Iridium plug, maybe try these in the TR6 heat range. I ran Denso Iridium IT20's for several years, they worked real well but were pricey.
Old Jun 6, 2009 | 01:41 PM
bombebomb's Avatar
If you never want to pull them again, gap them even smaller than .035 for safty of not having spark blow out.
Old Jun 6, 2009 | 06:07 PM
RUDEDOG's Avatar
I use ac delco or autolite gapped at .045 and never had any issues.
Old Jun 6, 2009 | 09:05 PM
Z-RATED94's Avatar
Re read #2 two and don't read them then. Seriously, TR6 gapped at 35. Just remember their not going to last as long.
Old Jun 6, 2009 | 11:20 PM
93v8clone's Avatar
then get a diesel ,no plugs in there
Old Jun 6, 2009 | 11:35 PM
Josh'95Z28conv's Avatar
Why would you not be able to pull off 93 octane gas? LE2 on a 383 should be very mild.
I dont have any advice on plugs. I run a ngk racing plug recommended by lloyd, cant remember the number. Dont know how long they will last but I wouldnt expect too long. If I were you Id run ac delco platinums for long life.
Old Jun 7, 2009 | 01:20 AM
ENRKyle20's Avatar
The compression is a little high. I seem to be cursed when it comes to knocking.
Yea I think what I get will be Iridium plugs. I know those last a long time. you cant gap those so I dont have to worry about that.
Old Jun 7, 2009 | 07:15 AM
94zgreenmachine's Avatar
NGK TR6 is what I used.
I had the same compression. 93 is no problem.
We should have swapped PCMs. You could have had that tune. Zero spark knock.
Old Jun 7, 2009 | 10:39 AM
Why can't you gap an Iridium plug? The ground strap can be moved easily with the correct tool, without damaging the center electrode, just like any other plug.
Educate me.
Old Jun 7, 2009 | 11:36 AM
ENRKyle20's Avatar
I was reading a thread that said that the Iridium plug were brittle and if you tried to gap them the ground strap would break off. maybe you just need to be more careful?
Old Jun 7, 2009 | 11:37 AM
ENRKyle20's Avatar
and green. yea that would have been a good idea. For the most part this is the exact same motor that you ran with that pcm. If you still have the equipment you can just read a copy of the tune and send it (If you use tunercat). That would be cool :-)
Old Jun 7, 2009 | 11:41 AM
bombebomb's Avatar
You should not be getting knock at 11.9:1 may want to get that checked out.
