What size torx socket to take apart the optispark?
Old Feb 7, 2016 | 12:12 PM
  #16
bravo351's Avatar
Re: What size torx socket to take apart the optispark?
Originally Posted by wrd1972
Once you have the screw how are you turning it into the tool?
First off, let me apologize for bumping such an old thread. I hope, once you read my addition, that you'll see it was necessary.
I wholeheartedly agree with the use of a TB screw as an E4 socket, and I didn't want to damage my threads either. Upon extraction, I found a smooth shank at the end of the screw a little over 1/8" tall, just enough for me to chuck up to with my 3/8" chuck drill. Worked like a charm and reinstalled the TB screw with no threadchasing required.
Hope this helps some other Googler along the way. Thanks!
Old Feb 8, 2016 | 02:20 PM
  #17
Chimera96's Avatar
yes you can use one of the screws from TB plate. There is enough end that is not threaded to use vice grips to clamp then use as a tool.
or
just put a #4 torx machine screw and get a 1/4" threaded barrel same threads and use a 1/4" socket/nut driver
some IIRC found the correct torx socket at harbor freight for a few $ also
the one in pic comes with the MSD C&R
Attached Thumbnails What size torx socket to take apart the optispark?-opti-torx-1.jpg   What size torx socket to take apart the optispark?-opti-torx-tool.jpg
Old Feb 8, 2016 | 09:32 PM
  #18
GaryDoug's Avatar
Prominent Member
Or for about 10 bucks , you could do it the right way ;-)
6 Pc 1/4 in. Drive E-Socket Set
KYWes
Jun 14, 2022 06:52 AM
HectorM52
Jul 30, 2017 11:46 AM
Latronaxe
Jul 17, 2015 11:55 AM
CARiD
Jul 7, 2015 08:19 AM
