What size torx socket to take apart the optispark?
Re: What size torx socket to take apart the optispark?
i had to get one made from snap on, because i checked about 6 stores and couldnt find it, so it costed me a little more than 30 with shipping, and i can sell you mine if you want it because im going to sell my camaro
just learned today to take off the screws on top of the throttle body, turn them over and voioa you have the right tool to take them off. hope this helps.
If that's the case, then why not just pick up a torx screw from a hardware store, and just make a driver out of it, instead of damaging the threads on one of your TB screws.
The other option is getting a E4 socket from Snap-On, Mac, you might be able to special order one from Sears.
Originally Posted by lt11997
Use a pair of vise grips on the very end of the screw, but be careful so you can reuse the screw.
But as stated above I'm sure Craftsman makes one by now.
Before I invested in the correct socket, I used a 'double nut' on the TB cover screw.. [no damaged threads, and you can use a socket, or nut driver, on the nut.. ]
This sounds good as to not ruin the screw.
Lisle Tools used to make a deep E4 socket that works perfect for $8, but discontinued it. You might be able to still find it at auto parts stores that carry their brand, Murrays, CarQuest, etc.
