What size stainless fuel lines?
Subscribe
Apr 8, 2006 | 06:10 PM
What size Stainless fuel lines would be good for about a 600BHP engine with 42# SVO injectors @ 43.5psi?
Reply
Apr 8, 2006 | 07:16 PM
Re: What size stainless fuel lines?
I run 800(flywheel)HP, including a 300-shot of dry nitrous off a -6AN supply line (similar to the 3/8" stock diameter on the supply side) and a -6AN return line (just slightly larger than the stock 5/16" return line). I'm running 78# injectors. The only thing that's different is I feed the supply lines into the back of both rails, and take the return line off the diagonal cross-over tube at the front of the rails, then to a Weldon AFPR mounted under the cowl.
Reply
Apr 8, 2006 | 11:50 PM
-8AN feed and -6AN return should be MORE than enough.
-B
Reply
Subscribe
