What size injectors for "stock" 93
Old May 15, 2004 | 10:17 AM
93Z4ME's Avatar
I've got a 93 with 165k miles and a cylinder just quit on me.
I changed the wires because I had some that were split (MSD's after 14 months!)
I pulled the plugs (20k miles on NGK Iridiums) and #1 insulator was pure white, so I'm assuming I have a stuck injector.
I figure it's probably time to change the injectors, My question is:
Stock 93's are 22lb, what should I replace them with (brand/size), I don't want to have to retune or get an adjustable regulator yet.
The motor is basically stock with all the usual bolt-ons (see sig)
Thanks in advance for the help
Old May 15, 2004 | 10:27 AM
Scream And Fly's Avatar
I think you can go to 24's without a problem.
Greg
Old May 15, 2004 | 11:07 AM
polcat1p's Avatar
I have a 93z that i switched to a 94, and just got used 24 injectors for the pcm tune. If you want i can sell you my stock set of injectors with $100k for $20 shipped if you want a cheap replacement
Chad
Old May 15, 2004 | 01:12 PM
n2ceptor's Avatar
Accel #24s on a stock '93 and no probs here......
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
