View Poll Results: Injector size
24-30#
20.00%
30-36#
35.00%
36-40#
10.00%
40# or larger
35.00%
Voters: 20. You may not vote on this poll
What size injectors do you run? POLL
Old Apr 20, 2005 | 11:35 AM
vette40th's Avatar
What size injectors do you run? POLL Old poll, go to new one, see last reply
Okay guys, just answer the question. You can add why you run a certain size injector, test data, recommendation from whoever , and post HP results etc.
30# with 396 520fwhp.
Old Apr 20, 2005 | 11:39 AM
JustNO's Avatar
Re: What size injectors do you run? POLL
hehehe I start first;
I will use 37lb injectors for my ~550bhp LT1
Old Apr 20, 2005 | 11:40 AM
vette40th's Avatar
Remember, its just a poll not a thrashing.
Old Apr 20, 2005 | 11:42 AM
JustNO's Avatar
Please write here your engine's hp (at flywheel).. Its important too..
Old Apr 20, 2005 | 12:26 PM
LPEdave's Avatar
Could you clarify what button you want folks to click if they run 30, 36 or 40# injectors?
Or maybe I'm mis-reading something?
Dave
Old Apr 20, 2005 | 12:36 PM
tardy007's Avatar
Dave
I was wondering the same thing since I have 30#
Old Apr 20, 2005 | 12:50 PM
slimdawson's Avatar
530fwhp/514fwtq
Stock long block LT1 and 8# of boost. 42.5# Lucas injectors.
1-bad-z28's Avatar
i'm going with a blower on a 355 so it will be above 40. I should easily see 550rwhp
Old Apr 20, 2005 | 01:07 PM
atljar's Avatar
Voting up top is kinda goofy the way its setup.
Im running SVO 36lb at 54 psi. That should handle just shy of 600fwhp NA safely.
Motor is 11.3:1 383, AFR, single plane etc etc
Old Apr 20, 2005 | 01:11 PM
ScreamnChicken's Avatar
Stockers. I'm guessing 351rwhp puts me around 400-410bhp or so???
Old Apr 20, 2005 | 01:26 PM
vette40th's Avatar
Dave
Just click on the best one, or all three, ie then write it in the post.
If the poll could be written differently, please let me know how to fix it, so I can put individual injectors. I only had 4 places to put the sizes. OOPS, I found it, but I dont know if I could change it. See what happens when the coffee hasnt hit me yet, I am in Hawaii, so the time was a little early.
Old Apr 20, 2005 | 01:28 PM
BRENTT94Z's Avatar
Injectors in the Sig!
I dont know how to fiure FWHP but I put down
417rwhp/ 410 lbtq
Old Apr 20, 2005 | 01:37 PM
Black_95Formula's Avatar
I should be close to about 500 fwhp, running 42# Lucus injectors.
Old Apr 20, 2005 | 01:38 PM
vette40th's Avatar
Re: What size injectors do you run? POLL go to new one.
I am going to restart this, as I cant modify the # of choices.
http://web.camaross.com/forums/showthread.php?t=360213
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
1775.Z28
Jan 11, 2015 10:51 AM
nophix
Nov 30, 2014 10:26 PM
