what size injectors?
Old Apr 21, 2011 | 07:31 AM
dennis5374's Avatar
Ok i know you take the flywheel hp and multiply by..07. Im figuring that the car should had around 500fwhp after a dyno tune. I plan on running a 150 shot at the strip so should this be taken into consideration before i purchase the injectors?
Old Apr 21, 2011 | 07:33 AM
RamAir95TA's Avatar
Re: what size injectors?
Wet or dry shot?
Old Apr 21, 2011 | 08:27 AM
GRSCamaro's Avatar
http://www.witchhunter.com/injectorcalc1.php4
Try this calculator.
Old Apr 21, 2011 | 09:54 AM
dennis5374's Avatar
Zex wet kit. Was gonna go with a 150 shot for strip use. The motor when finished should be in the 450-500 fwhp range i just don't wanna sell myself short. 42 lb veno
s sound about right.
Old Apr 21, 2011 | 04:46 PM
A wet kit doesn't use the injectors to add fuel for the nitrous. You size the injectors for the normally aspirated HP. Are you indicating 42# Venom injectors with "42 lb veno"? That would be a mistake. Stick with the proven brands, not the "ricer" brands.
42 #/HR injectors will be fine. Just get good ones.
Old Apr 22, 2011 | 01:04 AM
dennis5374's Avatar
I've heard alot of complaints on here about the accel injectors. I found a set of bosch 36# on ebay for 260.00. I'm gonna purchase those because i thought you added the hp u gain from the nitrous also. I should be around or a little under 500 hp.
Old Apr 22, 2011 | 01:06 AM
dennis5374's Avatar
Although they wouldn't leave much room for hp gains so maybe ill death a little more extensively for bosch 42# injectors
Old Apr 22, 2011 | 03:19 AM
MikeGyver's Avatar
There's no reason to not get the 42#'s. leave plenty of overhead.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
