What size (height) tires should I be looking at getting?
I've got a 9" with a 6spd. Gonna put 4.33 gears in the 9"
heads cam 383 200shot nitrous in the future, i dont know if i will have enough money this winter for it though Whats the optimal rpm for crossing the traps? above or below peak hp? cant decide on whether a 26" or 28" tire |
damn
Another useless post by the resident ricer and moron.
You want to cross the traps at the top of your powerband in a gear, or as close to that as possible |
well i think im gonna use the 26" since i can get a good deal on them. And they should be optimal for at least a 150 shot.
thanks guys |
A 26 inch tall tire at 120mph would put you at about 6720 rpm in fourth gear in the traps.
A 28 inch tall tire would put you at about 6240 rpm. |
you will run out of gear with 4.33s and 26 inch tires. My buddies 396/nitrous runs out of gear even with the 28" and 4.30s. Hes swapping out gears to something higher this winter.
Heres a handy sheet for calculating stuff. http://www.f-body.org/gears/ |
these are the tubes i would need right? http://store.summitracing.com/partde...t=SUM%2D710002
If you are going to run the 26in I would just go to autozone. And pick up the tubes for 12.00 each and save some cash. That is what I have on my car. And I have no problems with them.
