What size header bolt
Old Jun 2, 2006 | 02:39 PM
xxvann's Avatar
1994 TA, stock (ported) heads, AS&M headers (3/8" thick flange).
ARP has a couple of options for bolts:
- 3/8" diameter x .750 (bolt UHL)
- 3/8" diameter x 1.000 (bolt UHL)
Advice?
Old Jun 2, 2006 | 03:13 PM
joeSS97's Avatar
Re: What size header bolt
You want the 1'' long bolts.
Old Jun 2, 2006 | 03:24 PM
wrd1972's Avatar
Use the 1", you will have twice the bite inside the head. You are less likely to strip out holes. There is absolutely NO reason to use 3/4' bolts period.
I really like my stainless steel ARP 1" hex head bolts. Dont get 12 point cause you can not get an open end wrench on the head. I can assure you will need to use a ground down 5/16" open end wrench on you AS&M headers.
Old Jun 2, 2006 | 03:35 PM
xxvann's Avatar
I thought the bolts were 3/8" head?
I put the headers on in 2000, but after the motor was built last year my copper gaskets went missing and some paper gaskets were installed, which have since burned.
I do remember having to shave the open end wrench, tho. Damn those headers.
Thanks for the advice!
Old Jun 2, 2006 | 06:35 PM
Mike96z's Avatar
Use 3/8 Head bolts from ARP or something and use the copper gaskets, they are great, use an open end wrench to tighten or better the ratchet wrenches are perfect for the ones that are easy to reach.
Old Jun 2, 2006 | 06:54 PM
94_PatriotRed_Z's Avatar
1" ARP is the way to go
Old Jun 2, 2006 | 07:07 PM
ulakovic22's Avatar
1" Breslin Locking Bolts is the way to go IMHO.
Old Jun 2, 2006 | 11:42 PM
user 647483's Avatar
I used stage 8 locking 1" bolts.
Mr Gasket 3/4" were crap, I won't make that mistake again
Old Jun 3, 2006 | 06:24 AM
xxvann's Avatar
Thanks a ton for the advice! I ordered the ARP stainless 1" bolts and the Mr Gasket copper gaskets.
The fun is over, the pain begins with the install.
Old Jun 3, 2006 | 10:32 AM
It'll all feel better when you bury your foot into the carpet
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Mar 16, 2015 09:45 AM
crazypurgatory
Jan 12, 2015 10:45 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
