What size bolts to block off air and egr?? Also gasket?
Old Jun 15, 2003 | 03:14 PM
speed76demon's Avatar
exactly what the post says what size of bolts do i need to eliminate these?? Also what gasket is better the fel pro 1406 or the 1470?
Old Jun 15, 2003 | 03:19 PM
turbo_Z's Avatar
what headers do you have?
the 1406 is what most guys on here use so i went with them and can say they have held up a year after i installed my headers.
Old Jun 15, 2003 | 05:01 PM
94ZVert's Avatar
5/8 inch brass plugs will fit perfectly inside those tubes. They also look pretty nice too.
And yeah, the 1406 is fine for your application.
Old Jun 15, 2003 | 09:36 PM
av8er's Avatar
If you are putting block off plates for the EGR valve and EGR pipe on the back of the intake manifold, you will not need any additional hardware for the EGR stuff. Both components are held on by nuts and you can reuse the gaskets with your block off plates.
JeffA
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
Jul 4, 2005 05:00 PM
