What size bolts?
Old Oct 20, 2003 | 06:44 PM
Rodrigues's Avatar
What size bolts?
Mainly the length is the most important but I think i will have to cut my old panhard bolts off. What size is this bolt that connects from the panhard bar to the rear end? Also, what size bolt are the lca's that connect to the subframe.
Old Oct 25, 2003 | 11:55 AM
Lt1tko5o's Avatar
The panhard bar uses special bolts, they have a 12mm thread, but the bushing part of the bolt is larger. You can't get them at the hardware. Once it's apart you'll see what I mean. I drilled out the bushing on the panhard bar and the frame to 1/2" and used a hardened bolt from the hardware. For the LCA's, 12 mm 3 1/4" is what it takes.
Brian
Old Oct 25, 2003 | 03:04 PM
LCA bolts 12 x 1.75 x 95
http://web.camaross.com/forums/showt...hreadid=182922
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
