What should the O2 reading range be at WOT?
Old Oct 19, 2005 | 05:13 PM
2QUIK6's Avatar
What should a general O2 reading be at WOT on an LT1 for rich or lean?
This if course is when the O2 reading is pretty much static. I know a WB is really the way to go but I'm trying to get a rough idea of where I'm at.....for instance on my turbo Buick you try to target an optimal .780mv for most power..much above 810mv and you are considered rich.
Just wondering what it should be on the LT1 car, currently my WOT blasts are resulting in O2 readings around 920mv.
Old Oct 19, 2005 | 05:19 PM
madwolf's Avatar
Re: What should the O2 reading range be at WOT?
Depends on a lot of different things. (such as temperature, individual setup, etc), but typically, you want to see them around 920 or so (on an internally modified N/A car). On stock or close to stock cars, that is a bit lower. (885-900)
Old Oct 19, 2005 | 05:29 PM
atljar's Avatar
Dittio. Low 900s is where I made most power with mine. On a wideband that equated to high 12:1 range
Old Oct 20, 2005 | 07:22 AM
2QUIK6's Avatar
Cool, thanks for the info, so my 920 was about right...now I need to figure out another reason why I'm getting 6-7 degrees of knock at WOT with 93 gas and I've already removed 2-3 degrees of timing from the stock tables once before when it was getting knock.
Old Oct 20, 2005 | 07:50 AM
Honda Hunter's Avatar
Mabey it's false?
Old Oct 20, 2005 | 03:12 PM
2QUIK6's Avatar
Originally Posted by Honda Hunter
Mabey it's false?
Could be, I'm going to fill it with some 101 gas and put a fuel pressure gauge on it and make sure everything is cool there.
carl.froehlich
Mar 13, 2015 12:38 AM
jayblev95
Jan 20, 2015 01:30 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
