what should my times be
Old Jun 8, 2003 | 11:38 PM
fast_TA_95's Avatar
Cool what should my times be
i have a 95 TA with K&N cai, Grantetelli MAF sensor, Trick Flow Inlet Elbow, MSD 6AL, MSD blaster coil, 8.5 MSD wires, NGK Iridiums, Holley adgustible fuel pressure regulator set at 51psi, B&M ripper shifter, Jet PCM, Jet fan switch, Intrax drag launch coils, KYB shocks, ZEX 125 HP shot, ZEX bottle heater, MSD timing control module, retarded 5. I want to know what you think i should be running. ran a 13.613 becasue of traction problems, ordered Lakewood traction and lift bars and slicks. What should my times be?????????????????????
Old Jun 8, 2003 | 11:56 PM
fast_TA_95's Avatar
what u think
common what u guys think im goin to the track this weekend and i want to know if you guys think ill be in the low 12's please post a reply!!!!!!
Old Jun 9, 2003 | 12:29 AM
thewinner's Avatar
i vote that you will break the rear end with the slicks, especially if you spray out of the hole. you should be high 11s at least with those mods.
Old Jun 9, 2003 | 05:13 PM
fast_TA_95's Avatar
not out the hole
im not gonna spray out the hole just when i grab traction in first do you think ill still be easily in the 12's and do u think i m will really hurt my tranny
Old Jun 11, 2003 | 05:23 AM
Slayn's Avatar
12.0-12.4 @ 110-115mph with "decent" traction...
That's what the usuall Bolt-on/100-150 shot LT1 does with around a 1.9-2.0 60 footer... Cut them 60's down to 1.6-1.7 area and you should see high 11's (If your rear/tranny will hold that is )
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
