Here is a list of mods I already have.
Gutted CAT with high performace exhaust.
After market fuel injectors pushing around 60 psi of fuel pressure.
The chip has been reprogramed.
The timing has been changed.
After market spark plugs.
Drop in after market K&N.
After market MAF.
Next one for sure is going to be an K&N intake but what after that?
After market MAF.
What programming do you have? Why do you have aftermarket fuel injectors? Why do you have such high fuel pressure?Originally posted by Cerwin Vega Fan
I'd recommend removing all of that crap and starting from the point where you have just the gutted cat and exhaust. Then do a cold air setup like the K&N FPIK.
Quote:
Originally posted by $hawn
If you got an auto, I'd get a tranny cooler, there fairly cheap, and are good insurence, and easy to install too.
Yeah I have an auto. What does the tranny cooler do? Just keep the conveter cool?Originally posted by $hawn
i agree with the other guy...what is with that high of fuel pressure??
if you are lookin for simple bolt ons you could go for pullies, air foil (almost useless) and maybe an electric water pump...
if you want something bigger...get headers or a higher stall with a cooler and shift kit
Well guys I brought this car used and really I do not know what is really what. How could I tell if it is cat back or full exhaust? Also I really have no clue why the fuel pressure is so high, I just know that is why the guy told me. You can tell they are after market injectors but I need to find a way to check the pressure to make sure it is not set to high.
Since you already have upgraded your injectors, why not run nitrous? Is it possible the guy before you was runninga dry kit and that's why he upgraded the injectors?
Quote:
I hope not.Originally posted by Toms30th
