what should i replace?
Old Jun 16, 2003 | 12:32 PM
iniviate's Avatar
ok... so i've got an unvented opti with probably 130k on it.
i'm rebuilding the motor, so i've got everything apart. just for fun, i pulled the cap off my opti. the cap and rotor are in very rough shape. infact, i'm not sure how there wasn't a miss. the optical sensor is clean, and the bearing is tight.
this is pretty much the only part i have left to buy. i should be assembling the motor tomorrow. i'd like to have the car running this week.
basically... what should i do?
should i just replace the cap and rotor? if so.... where would i buy them? neither pep boys or autozone had a cap & rotor.
should i buy a new unvented opti?
should i convert to a vented opti?
when i started, i was going to switch to the LS1 coils.... but it's pretty much at the end of the project here... so the funds are a little tight.
i'm worried that if i convert to a vented opti that things will snowball on me, like everything else i do. see... if i go vented, i might as well get a double roller timing chain. if i do that, i'm going to have to get an electric water pump..... all in all, this would probably cost me $500+ .... i'm not looking to spend that kinda cash in this area of the car.
anywho... give me your opinions on what i should do.
Old Jun 16, 2003 | 12:36 PM
Style's Avatar
Vented or not-vented, i would replace the opti. Something you will not regret. The price on one isn't too bad compared to the trouble of replacing it later.
Old Jun 16, 2003 | 12:39 PM
Gripenfelter's Avatar
While you're at it you might wanna consider getting a new timing chain put it.
Old Jun 16, 2003 | 12:51 PM
iniviate's Avatar
changing the opti is cake.... i'm not worried about that. last one i did for someone took 45 minutes.... start to finish. i'm thinking if there isn't anything wrong with my optical stuff.... why should i change it?
grip - i have a new timing chain, just not new gears. (the chain is only like $20)
KYWes
Apr 15, 2015 05:48 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
stopthatman
Feb 9, 2015 09:00 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
