What should I get next?
Old May 5, 2008 | 11:38 AM
chucksz28's Avatar
Cool What should I get next?
Folks:
I have a 95Z28 with 157K miles and it runs just fine. No leaks, squeks, etc. It has the LT4 Hot Cam Kit, CAI, Borla exhaust wide open and Pacesetter Headers.
My question is what can I bolt on next? I know it's getting along in miles but It's just a weekend warrior and runs just fine. I may eventually go the 383 route, but would like to tinker with it some more, something I could bolt on or something that would'nt be a big deal install wise.
Anybody got any ideas on how I could get a few more HP?
Chuck
Old May 5, 2008 | 11:59 AM
2000GTP's Avatar
Maybe start looking into some suspension upgrades, better tires, ect.
Old May 5, 2008 | 12:07 PM
1993zlt1's Avatar
lol Save ur money, Way i see it is u already got a really quick car, by a bike, unless U want to go all out and get all new suspension or go for a 355/383/396 build.
Old May 5, 2008 | 12:42 PM
lovescamaros25's Avatar
Maybe suspension upgrade,make sure the tires are up to par,and then think about some 3:73 gears,EWP(electric water pump),and a PCM tune which I assume you already have done before after the bumpstick swap.Just dont waste your hard earned money on UDP's or TB air foil.
Old May 5, 2008 | 12:57 PM
slomarao's Avatar
everyone telling you to buy suspension upgrades because instead of adding more hp you want to make better use the hp you already have. A gear may be something you should look into or if you want more power a set of ported heads. If your willing to spend a grand or a little more i would checkout LE and AI. Both do very good work, if your looking to spend a little less a ele water pump and a 52mm tb may be your ticket to 15 hp.
Old May 5, 2008 | 01:55 PM
pcgamer4life's Avatar
Gears and a tune would probably net you the most gain for the price now.
Old May 5, 2008 | 01:56 PM
ss.slp.ls1's Avatar
+1.
Old May 5, 2008 | 03:13 PM
chucksz28's Avatar
Cool
Thanks all...
I had a tune with the LT4 Hot Cam kit, and am now veering towards 3.73 gears and maybe a 52MM throttle. any suggestions on how/where/how much for the 3.73 gears? As for the 52mm throttle, is the Granatelli one decent or is there one better?
How's that sound??
Chuck
Old May 5, 2008 | 03:28 PM
2000GTP's Avatar
Originally Posted by chucksz28
Thanks all...
How's that sound??
Chuck
You will probably pay around 500 grand total for a gear swap. As for the throttle body, Granatelli doesn't make one to my knowledge, they make mass air flow sensors, maybe you are confused? I would stay away from the aftermarket mass air flow sensors.
Old May 5, 2008 | 06:13 PM
Mtxz453's Avatar
supercharger
Old May 5, 2008 | 10:56 PM
1993zlt1's Avatar
Originally Posted by Mtxz453
supercharger
might need to Up those internals 157k with supercharger=bad, possibly a piston threw oil pan.
Old May 5, 2008 | 11:08 PM
1996camaroSSclone's Avatar
I know a car running with 150k running 15lbs of boost through a D1SC and sometimes sprays 150 shot so I'm sure 5 or 6psi wouldnt hurt if you didnt go WOT everywhere.
Old May 5, 2008 | 11:40 PM
1993zlt1's Avatar
i seen some with less then that miles crack blocks and throw rods and spin cam bearing. Its way to common to spin cam bearing on our cars. i know at least 3 personily and herd it happens alot via z28.com.
Old May 5, 2008 | 11:43 PM
If they run there cars like I used to run mine it's not hard. It depends alot on how you drive.
Old May 6, 2008 | 12:30 AM
bombebomb's Avatar
Thanks all...
How's that sound??
Chuck
I had 600 total in swap, 250 for install, 350 in parts that was ring pinion, rebuild kit.
