What should I expect...
Old Aug 1, 2004 | 03:15 PM
TheBiz's Avatar
What should I expect as far as HP numbers and 1/4 mile times for the setup in the sig. I haven't had a chance to get to the track or the Dyno in Bloomington. Help a guy out!
BIZ
Old Aug 1, 2004 | 03:48 PM
RE AND CHERYL's Avatar
Re: What should I expect...
On Drag radials or slicks you should run real low 12s or high 11s. I've seen the same mods with a Hot cam or CC305 run 12 flat, so you shoud be able to do better than that.
Old Aug 1, 2004 | 08:27 PM
besz28's Avatar
if your heads were ported decent i see no reason your not at 380+rwhp and depending on a lot of track variables such as weather, track prep etc.... low 12's should be yours. good luck
Old Aug 1, 2004 | 11:25 PM
MTL_Z28's Avatar
You've got lots of power there's no question about that, but I think how well your car performs at the track will depend on how well you can get all that power to the ground.
Mikes25thAnnTA
13
Jun 7, 2006 05:22 PM
TRSCobra
3rd Gen / L98 Engine Tech
Mar 26, 2006 01:44 PM
Darth Xed
Jan 14, 2005 02:24 PM
