what should cylinder compression be in an LT1?
Old Nov 3, 2005 | 08:33 AM
12sec94z28's Avatar
Question what should cylinder compression be in an LT1?
what the title says.
Old Nov 3, 2005 | 09:21 AM
87lt1rx7's Avatar
Re: what should cylinder compression be in an LT1?
10.4:1
Old Nov 3, 2005 | 09:35 AM
12sec94z28's Avatar
thanks but i mean PSI....i found it. should be 100 minimum.
Old Nov 3, 2005 | 11:39 AM
HBHRacing's Avatar
100 PSI min means nothing. Cranking PSI on a healthy motor is around 180. All should be withing about 5% of each other.
Old Nov 3, 2005 | 11:44 AM
There is no "correct" answer, but I'd sure like to see 180psi rather than 100psi
Pressure observed during a compression test is dependant on too many things:
-how warm was the engine
-how strong is the batter/starter combo
-how wet are the cylinder walls
-was the throttle body held wide open
-how many crank rotations were used
-did any fuel get into the cylinders
-were all the plugs removed
Probably a few more variables. The important part is how close were the readings from cylinder to cylinder. You are looking for readings that are out of line with the others. Shop manuals will typically tell you to look for no more than 20% variation, but I don't think you wany anything that sloppy for a performance engine.
Old Nov 4, 2005 | 10:02 PM
96capricemgr's Avatar
Rocker ratio might even have a small effect.
My 180K mile Roadmaster wagon cranked 195-200 on the few cylinders I quickly checked this has a different cam than the f-body version of the LT1 and larger combustion chambers in iron heads making a lower static compression ratio.
oldschool
Feb 9, 2016 09:21 PM
pimpss96
Feb 12, 2015 01:28 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
