what sensor reads RPM?
Old Mar 24, 2005 | 10:10 AM
slp223's Avatar
What sensor reads Rpm and sends it to the computer? Freescan read the when my car is turned off it is turning 50rpm yet when i try to crank it rpms come up to 125 ( i faild to mention my car will not start) what sensor sends this signal? does it come from the opti? I have not troble codes and no spark.
Old Mar 24, 2005 | 11:00 AM
disco192's Avatar
Re: what sensor reads RPM?
it comes from the opti
Old Mar 24, 2005 | 12:21 PM
RE AND CHERYL's Avatar
The low and high resolution signals from the Opti are sent to the PCM and turned into a crank position and RPM signal.
Do you have spark? How about fuel pressure?
Old Mar 24, 2005 | 12:44 PM
slp223's Avatar
so if i am getting an rpm signal the opiti is working? it it has no code?
Old Mar 24, 2005 | 12:46 PM
slp223's Avatar
i got it running my damn accel 300+ box died funny thing is i was just telling some folks how happy i was with it. o well it was 6 or 7 years old that probbaly a good live span for one.
Old Mar 24, 2005 | 02:15 PM
slp223's Avatar
thank you for your help it you replied.
Old Mar 25, 2005 | 05:40 AM
Tom Piper's Avatar
On all LT1/LT4 engines, the computer uses the signals from the Opti-Spark to determine engine position and rpm in order to know when to fire the plugs and fire the injectors.
If your vehicle has a tach filter (early LT1), the rpm signal for the tach and ASR comes from the coil, not the Opti-Spark signals.
The later LT1/LT4 engines create a dedicated tach signal in the ECM, which is derived from the Opti-Spark signals, and sends it to the tach and ASR.
Tom Piper
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
