What is the seal on the timing cover???
Old Jul 24, 2006 | 03:34 PM
Heatmaker's Avatar
Advanced Member
ANy body know what that seal on the timing cover that the opti goes through is called? I can't find it? all I can find is the crankshaft seal.
Old Jul 24, 2006 | 04:19 PM
Heatmaker's Avatar
Advanced Member
Re: What is the seal on the timing cover???
Optispark Drive seal...
12552428 -GM Optispark Drive Seal - (In Timing Cover)-1995-1997 L99 / LT1 / LT4
For Use With Vented Pin Drive Optispark
Old Jul 24, 2006 | 04:20 PM
Stoopalini's Avatar
I know it comes in the Timing Cover Gasket Set. You can get a timing cover gasket kit from Advance Auto or Autozone for ~$15. This is a felpro kit which has 2 o-rings, all 3 seals which press into the timing cover (water pump drive, opti drive, balancer hub), the timing cover to block gasket, and waterpump gaskets.
Thomas.
Heatmaker's Avatar
Advanced Member
Thanks.
Yeah I should of ordered to kit but I never knew they made one.I ordered everything in pieces, but somehow forgot this gasket.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
