View Poll Results: what rotating assembly and why? thanks
383 w/ 5.7 rods
47.06%
383 w/ 6.0 rods
23.53%
396 w/ 5.85 rods
11.76%
396 w/ 6.0 rods
17.65%
Voters: 17. You may not vote on this poll
what rotating assembly would you go with?
Old Jan 29, 2005 | 02:24 PM
87transam383tpi's Avatar
I'm starting a build up for my LT1 and i'm going w/ a ATI procharger w/ 12-15lbs of boost on it. the car sees about 3000-4000 miles a year w/ some ocasional trips 200-300 miles long. what rotating assembly would you go with? thanks
Josh
Old Jan 29, 2005 | 03:13 PM
TQdrivenws6's Avatar
Re: what rotating assembly would you go with?
I voted the 383 with 5.7 rods. With that much boost, you will need pistons in the area of a -30cc dish to get the compression down to a point where street gas is an option. The shorter rod won't be anything that you will notice, and it will give the best compression height of all the setups that you listed.
Old Jan 29, 2005 | 03:19 PM
rskrause's Avatar
Moderator
The worst choice is clearly the 396 with 6" rods. That means a compression height of just a little over an inch. This is not comaptible with the pistons you need to run high boost on pump fuel (i.e. low compression) and the thick ring land needed.
Rich
Old Jan 29, 2005 | 04:21 PM
DavesLT1's Avatar
Rich
is the 396 with 6" rods ok for an engine that is N/A?
Old Jan 29, 2005 | 07:02 PM
Kraest's Avatar
Retired
Definetly. That's what I ran in my Z28. 120+ mph traps at 3870 lbs on ported LT1 heads and a hydraulic roller.
Mike
Old Jan 29, 2005 | 07:23 PM
DavesLT1's Avatar
Mike
good, because I already bought that kit.
Old Jan 29, 2005 | 07:34 PM
rskrause's Avatar
Moderator
Yep.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
cmsmith
Aug 27, 2015 06:37 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Dams76
Aug 20, 2015 08:28 AM
