What is a REV KIT?
Old Nov 19, 2003 | 10:40 AM
Camaro_Guru16NY's Avatar
Question What is a REV KIT?
I saw on a bundh of posts that some people had rev kits in adjacent to their cams such as CC306. What exactly is the kit and what does it do, Prices, requirements, is it really needed.
Later, guys,
-JOhn
Old Nov 19, 2003 | 10:41 AM
Heatmaker's Avatar
Advanced Member
Yeah...what is a REV kit?
Old Nov 19, 2003 | 03:52 PM
kmook's Avatar
Advanced Tech Moderator
http://www.airflowresearch.com/pages/hydra_rev.htm
It adds spring pressure to the lifter body to keep the lifter on the cam. So that you can rev a setup higher without having valve float. Reason you use this instead of just using a beefier valve spring is valve springs put pressure on the plunger and can collapse a hyd roller lifter.
I think they cost around $200.
Old Nov 19, 2003 | 03:57 PM
Heatmaker's Avatar
Advanced Member
So thier basicly Vavle springs? How much do they cost where cna one purchase one? Do they add hp?
Old Nov 19, 2003 | 08:24 PM
Z28SORR's Avatar
They do not "add" hp, per say. They allow you to rev. higher, which may be where your hp is. These are usually only for extreme rpm cams. And most if not all cam. manufacturers sell them.
Old Nov 19, 2003 | 08:43 PM
Transamdriver's Avatar
Here is a picture of mine installed.
http://www.auburn.edu/~doddjom/cam10.jpg
http://www.auburn.edu/~doddjom/cam12.jpg
Old Nov 19, 2003 | 08:45 PM
96z's Avatar
96z
They decrease or stop valve float allowing you to gain back or see the HP you could be loosing. Its mostly used for high revving motors.
Old Nov 19, 2003 | 09:20 PM
jim88iroc305's Avatar
Nic pics, really nice pics!
Old Nov 20, 2003 | 10:24 AM
So would these be needed on say a stock LT1 with CC306 or is that not enough cam for that set up.
Later,
-JOhn
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
