What resistor value bypasses the air pump?
Old Sep 22, 2003 | 05:30 PM
JohnsSS's Avatar
Question What resistor value bypasses the air pump?
What resistor value is needed to put in the airpump plug so that the SES light will not come on????
Any help is appreciated. If noone knows could anything be screwed up by buying many different resistor value's and doing trail and error???
Thanks.
Old Sep 22, 2003 | 05:35 PM
ibanez6rg's Avatar
Has your AIR pump been removed yet? My SES light never came on, although it is a 94.
Old Sep 22, 2003 | 05:40 PM
JohnsSS's Avatar
yes, air pump is removed, SES light comes on when car warms up.
Lyle A's Avatar
If the value is too low then it will cause a short in the circuit. Over 2K ohm should be ok and probably will work. Do you have the old relay to read the resistance of the coil? That is what the PCM sees in the circuit.
Old Sep 22, 2003 | 05:45 PM
JohnsSS's Avatar
k...thanks for the help
Old Nov 13, 2003 | 08:03 AM
JohnsSS's Avatar
ttt
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
W7Z28
11
Jun 25, 2002 02:23 PM
