what a releif
Old Dec 26, 2003 | 09:24 PM
glennxx1's Avatar
what a releif
well, after every 1 telling me how insanely un-mechanical i had to be for my drivers side header to take me 3-4 day to bolt up....pass side sliped right in only thing in the way is the dip stick.....what a releif, tlel me something, how the HECK do you get the dipstick out....all i found that i could unbolt was a bracket...is the dipstick pressed into the block or no?
Old Dec 26, 2003 | 09:27 PM
QCKZ28's Avatar
only one bolt holds it on, you have to pull it out very carefully
jesse
Old Dec 26, 2003 | 09:38 PM
crAzy95z28's Avatar
sheeeeeet....i ahd to bend mine to put it back in, and now i cant put the screw back in to keep the dipstick in place, but its pretty wedged inbetween my LT's so its not going no were..i check it every now and then to make sure...
randy
Old Dec 26, 2003 | 09:54 PM
QCKZ28's Avatar
dont worry i didnt rebolt my oil dipstick after the header installation. no problems so far.
jesse
Old Dec 26, 2003 | 10:08 PM
Birdman7389's Avatar
me neither, it didn't even have the bolt when i pulled it. I took a wire wheel to the end that slides into the block and made it a lot easier to put back in.
Old Dec 26, 2003 | 10:36 PM
S.J.S.'s Avatar
Mine too. I cut a half inch off and grinded it a lil. Still went in snug. Put a lil Ultra Copper around it to make sure it didn't leak. Bolt went back in.
You'e gonna need a friend to help you take out the stick and put it back. Someone has to be underneath.
Old Dec 26, 2003 | 10:48 PM
i took a flat screwdriver, and placed it on the bracket from underneath, a couple firm hits with a dead-blow hammer and it was out.
Bersaglieri
Dec 2, 2010 05:21 PM
Bersaglieri
Jul 6, 2010 06:07 AM
noboostnogo
Advanced Tech
Apr 9, 2009 04:42 AM
