What is the rectangular metal piece under the intake manifold?
Old Apr 7, 2003 | 07:41 PM
95LT1Z28's Avatar
Question What is the rectangular metal piece under the intake manifold?
I am doing a cam swap right now and just got the intake off. I am wanting to get my intake powdercoated and I was wondering what the rectangular metal piece on the bottom of the intake is and if it needs to be removed?
Jeff
Old Apr 7, 2003 | 08:02 PM
CoryB's Avatar
It's just a heat shield that helps to keep lifter valley heat from the A/F chamber...
Yes it can be removed without harm...
Old Apr 7, 2003 | 09:09 PM
PoorMan's Avatar
You should take it off. Underneath you will find five large plugs that need to be taken out also. I believe they are 9/16 allen head screws. The powercoater will be bead or sandplasting your intake before the powercoat and you don't want any beads or sand left in there. Taking them out insures a good flush after the blasting. You don't want any of this stuff to get into you cylinders later on. It will scratch the mess out of your walls and promote oil leakage past the rings. I just did mine btw. Pics in the sig. Anything not part of the orginal casting needs to be removed.
Jeff D.
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
