Flywheel - buy new or resurface old?
Old Apr 7, 2003 | 05:01 PM
CCRJon's Avatar
Question Flywheel - buy new or resurface old?
I am going to be purchasing a Centerforce Dual Friction Clutch Kit for my 97 Formula M6. (Please don't try to talk me out of it - LOL)
The car is on it's original clutch (as far as I know - I got the car w/ 47,000 miles on it)
I just need to know - should I resurface the existing flywheel, or buy a new flywheel (be it SLP or Centerforce etc etc)
The kit comes with the clutch disk, pressure plate, and the throwout bearing is in included. SPECS: 11in, input shaft 1-1/8x26
BTW - the new flywheel from centerforce is $347.69
the new flywheel from SLP is $355.00
What would everyone recommend ??
Old Apr 7, 2003 | 05:22 PM
Style's Avatar
Yes, you can resurface your flywheel, as long as you didn't slip the heck out of your clutch or run it down metal to metal .
I did a clutch at 62000 miles and it cost me about $25 to resurface it at the machine shop. Although it you are looking to buy the slp one, i believe it is a few pounds lighter, if you don't mind spending the extra $300.
Old Apr 7, 2003 | 05:40 PM
norcalstreet's Avatar
If you do buy a new flywheel make sure you get a shop to balance match it with the stock flywheel.
Old Apr 7, 2003 | 05:42 PM
funina91ss's Avatar
Sent you mail.
Old Apr 7, 2003 | 06:00 PM
Lost's Avatar
I hope you've done a search on that clutch that's all I've gotta say about that.
Yes, you can and should have your flywheel resurfaced.. there's no reason to buy a new one unless you want the "characteristics" of a lighter flywheel. You don't NEED a new one for any reason.. some people just feel that they are a performance upgrade.
HTH
Old Apr 7, 2003 | 09:35 PM
my96z's Avatar
HTH
Thas all I have to say about that and I "used" to have one.
If its not too bad you can get away with cleaning it off and just bolting it up. I resurfaced mine once. I hear you dont want to do it every time as it can get too thin.
Jeff
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F550maranello2
Apr 1, 2015 11:10 AM
Ringmaster72
Feb 25, 2015 03:15 PM
mattszm6
Dec 14, 2014 07:09 AM
