At what point do you need to upgrade your injectors?
Old Apr 23, 2013 | 09:27 AM
SSSean's Avatar
I am going w/ a LE2 Head package and was thinking about the LE 226/232 .578/.574 cam. 1 ¾ headers high flow cats to loudmouth exhaust. Thinking about sending in the intake for some porting to. This is pretty much a summer time daily driver.
Old Apr 23, 2013 | 10:39 AM
KW Baraka's Avatar
Re: At what point do you need to upgrade your injectors?
With a heads/cam upgrade, you're at the point where you'll want to upgrade to 30LB (SVOs if you can find them) injectors. You don't absolute have to......but it's a good idea.
If you go with a larger throttle body (52+ mm), then I'd definately recommend the upgrade.
KW
Old Apr 23, 2013 | 10:43 AM
RamAir95TA's Avatar
Typically you take your expected flywheel HP and multiply it by .07 to achieve recommended injector sizing (for NA only).
For example, if you expect 425fwhp you'd need (425 x .07) 30# injectors.
Old Apr 23, 2013 | 11:58 AM
PWR SHFT's Avatar
To add on to the thread, where would you find SVO injectors and what would be another brand/source to use?
Old Apr 23, 2013 | 12:13 PM
KW Baraka's Avatar
Originally Posted by PWR SHFT
.......where would you find SVO injectors and what would be another brand/source to use?
You can call ** http://www.fuelinjectorconnection.com/ ** to see if they have some (they don't always list when they have SVOs) or you can troll the Forums or Ebay for used ones and get them reconditioned.
As for other brands.....there are several (Accel, Bosch, Holley, MSD) but since I won't use them, I can't recommend them.
I've used Lucas and Siemens but have never seen either one that were below 42LBs.
KW
Old Apr 23, 2013 | 06:11 PM
Shangrila's Avatar
Fast fuel injectors.
Old Apr 23, 2013 | 07:08 PM
PWR SHFT's Avatar
Where to buy?
Old Apr 23, 2013 | 09:47 PM
SSSean's Avatar
Seems like I am right on the border of needing them.. Would a new Tune be in order if I stayed w/ my stock ones and upgraded later?
Old Apr 23, 2013 | 10:05 PM
Dan93z28's Avatar
You should tune it regardless or else itll run like crap with a cam like that. I say spend the cash for injectors now thatll also suit your needs later on. Id be scared running the stockers with anything more than a hotcam in the car.
Old Apr 23, 2013 | 10:30 PM
SSSean's Avatar
I should have been more clear Dan93z28.. I meant to ask, if I got tuned using stock injectors would a new tune be required if I upgraded to 30 lb injectors at a later date..
Old Apr 24, 2013 | 12:23 AM
97WS6SCharged's Avatar
You would need to change the injector constant in the PCM for the new injectors at the very least and to get things dead on you would probably need to adjust the tables very slightly. Check out Racetronix, they sell injectors for just about every application. The Fast 37 lb/hr injectors work well with the LE2 combo.
Old Apr 24, 2013 | 11:25 PM
SSSean's Avatar
Thanks 97WS6SCharged.. I will check out Racetronix.. my fuel pump died a couple of years ago and I put one of their pumps..
blkWidow
Sep 6, 2015 05:17 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
