what is this (pics in side)
Old Nov 28, 2007 | 06:35 PM
93camarochrisz28's Avatar
Post what is this (pics in side)
i know where the wire goes in the wiring harness but not in the car the harness go to the tranny but i can not find any where this would go on the tranny
Old Nov 28, 2007 | 06:43 PM
Looks like an oil pressure sensor.
Old Nov 28, 2007 | 06:58 PM
where would that go in the side of the block ??
Old Nov 28, 2007 | 07:00 PM
ajschult's Avatar
think it goes in the back of the intake manifold
Old Nov 28, 2007 | 07:02 PM
MeanGreen97Z's Avatar
Screws into the block just behind the intake manifold.
Old Nov 28, 2007 | 10:59 PM
SS RRR's Avatar
Not for a 93. That particular one goes just above the oil filter.
Old Nov 29, 2007 | 12:29 AM
sweet thank you guys soo much
Old Nov 29, 2007 | 07:22 AM
Vicious95Z28's Avatar
Bingo! we have a winner!
Old Nov 29, 2007 | 07:52 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If you're talking about SS RRR, then yes we do.
Old Nov 29, 2007 | 08:55 AM
Dave1980's Avatar
i shattered mine while removing my heads. I gave it gentle pressure after loosening with a wrench and bam the black part ripped off. (mine did not have that heat sleeve like in the pic above.) Anybody know where to get one cheap? I was wondering if I should go with a mechanical gauge at this point.
Old Nov 29, 2007 | 09:09 AM
White96Z28's Avatar
You should be able to pick one up for like $30 from your local NAPA or Carquest... Most of them stock them as a "oil pressure switch."
Old Nov 29, 2007 | 09:42 AM
Dave1980's Avatar
ok thanks.
Old Nov 29, 2007 | 12:00 PM
Guess, I should have looked at the sig. It still holds true for newer models.
Old Nov 29, 2007 | 12:20 PM
BTC's Avatar
BTC
In addition to the switches being mounted in different locations in early vs late model LT1's, the switches themselves are different aren't they? I know the switch in that pic appears to be different than the switch I replaced at the rear of my block behind the intake.
Aren't the two oil ports in place on all LT1's, allowing for the use of either switch, regardless of year. You would just have to mess with the wiring, and get the different switch, if you wanted to move it from its stock location?
Old Nov 29, 2007 | 01:31 PM
Yes, they are different. The early one uses larger threads. Either place can be used with the right sensor/adapters.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jlo
Feb 3, 2015 09:41 PM
CamaroZBoy
Sep 9, 2002 10:33 AM
