what pick-up for a melling 10554 pump
Old May 19, 2009 | 04:53 PM
Terran2k's Avatar
I am going to buy a melling 10554 oil pump, but what pick up do I need for it? I just dont want to buy the wrong part.
Old May 19, 2009 | 07:16 PM
wrd1972's Avatar
Cant remember if that is the Melling Select pump I used or not. I ended up using the stock pickup on mine. I also tack welded the thing on so there was NO chance of it falling off.
Old May 19, 2009 | 07:23 PM
josh77888's Avatar
with mine i bought the lowest sitting one, before i bought the car some dumbass tech put the wrong pick up on and it basically starved itself of oil
Old May 19, 2009 | 07:49 PM
lt1srule's Avatar
part #12550042
Old May 19, 2009 | 07:51 PM
lt1srule's Avatar
Melling Select 10554 pump (std vol/std pressure).
GM white spring 3848911 to put in it for higher pressure.
GM pickup tube, 12550042.
Melling IS-55E shaft.
Old May 19, 2009 | 11:34 PM
Terran2k's Avatar
thanks guys
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
jasonduaine
Apr 1, 2015 08:09 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ANDYZ28
Dec 29, 2014 09:13 PM
