what paint to use on an engine block?
Old Apr 24, 2006 | 08:52 PM
firebirdStud's Avatar
Talking what paint to use on an engine block?
Well, tired searchin, but nothing good came up that I could dig through... so Ill just ask and make it easier!
What kind (brand or whatever) paint did you use on your engine block? I had it painted red, but its flakin off and I want to do it good this time... so any suggestions? Yeah, I want to go red again!
Cody
Old Apr 24, 2006 | 09:29 PM
knta4dnu's Avatar
Re: what paint to use on an engine block?
Check out POR15 Products. Thier stuff is bulletproof.
Old Apr 24, 2006 | 09:47 PM
where do you find that?
Old Apr 24, 2006 | 10:02 PM
knta4dnu's Avatar
www.por15.com.
I used it on my exhaust.
I ordered the manifold gray and then used the brite aluminum finish on the heat shields. Only a couple hundred miles since I painted them, but no discoloration or peeling so far. It's good to 1600 degrees. I didn't keep the catalog they sent with my order, but I'm sure they had engine block paint too. Just check the web site. Also tried thier Boss Gloss for the interior. Not as bright as Armor All and helps repell dust. I'm sounding like thier spokesman, but I'm just a very satisfied customer.
Old Apr 24, 2006 | 10:25 PM
interesting. Just checked out the site. I may just pull the trigger on that crap and see how it works. It sounds pretty damn good.
Old Apr 25, 2006 | 12:44 AM
Evil Eric's Avatar
VHT has some great high heat products, I used it on my block.
Old Apr 25, 2006 | 06:35 AM
LameRandomName's Avatar
I like to use Equipment Enamel. Not plain enamel, not appliance enamel, EQUIPMENT enamel. Next best thing to powdercaot.
Generally you can find it at Lowes, Homeless Depot or Sherwin-Williams.
Link: http://www.mytscstore.com/detail.asp...productID=9166
You can also check out " www.eastwoodco.com/ ".
Lots of groovy stuff.
Old Apr 25, 2006 | 07:10 AM
97FormulaWS-6's Avatar
How did you prep the block before you painted it? Preping an item like that is what makes or breaks the paintjob.
You have to make sure ALL the grease, grime, oil, etc is gone before you can even think about having paint or any other coating stick reliabily.
De-grease the engine witha good quality de-greaser. Wipe it all down with some solvent to remove any residue; then use a good quality self-etching (Rusty-metal) primer; then paint with any normal paint.
The prep work; AKA cleaning the block; is what makes all the difference.
Old Apr 25, 2006 | 09:10 PM
I actually had the engine builder paint it before. It looked great, but after going through our parts washer it stripped some of the paint off. So, is por-15 the best of the best or what? Can you brush it on? do I have to sand to bear metal or just paint over the factory black and my red?
Old Apr 25, 2006 | 09:14 PM
FastZinTennessee's Avatar
I just went to Advance Auto Parts and got some engine block cleaner After hosing off the block, and scrubbing it down with detergent, the paint stuck no problem.
Old Apr 25, 2006 | 09:21 PM
its not that the block was dirty, I used a parts washer we had at work and just through it in there, got all the crap off. But it just seems like I can't get normal paint to stick to it for crap after a couple years. I want something that will last, ya know?
Old Apr 26, 2006 | 07:09 AM
The parts washer that u used is what did it. Even after the parts washer, do a very heavy wipe-down with some solvent to remove the parts washer chemicals. Most parts washers use a petrolium based solvent to remove all the grease and oil; you need a solvent like Mineral spirits or paint prep-sol to remove the film left behind from the washer.
Old Apr 26, 2006 | 07:17 AM
Johnny Ray's Avatar
Freebird
I use VHT also.
Preparation is the major factor in applying paint no matter what the case is.
(1) I set my engine on a engine stand.
(2) I scraped the large chunks off first.
(3) I used a hand held grinder with a wire wheel and worked every nook and cranny on the block until it was clean.
(4) Put a large catch-all pan underneath the engine and then started scrubbing it with solvent.
(5) Blew everything dry with a airgun.
(6) Repeated as necessary.
(7) Once I got the block as clean as I could, I then cleaned it off with a can of aerosol brake cleaner.
( 8 ) Went to AutoZone and bought 3 cans of Engine Block Ford Blue and some masking tape.
(9) Masked off everything I wanted to protect and wiped the block off one more time with the brake cleaner sprayed into a clean shop towel.
Good luck and have fun my friend!
Old Apr 26, 2006 | 07:30 AM
ok cool. Well, we will see how it goes... thanks everyone!
Old May 1, 2006 | 11:41 AM
did ya use any primer or metal sealant or anything like that?? or just spray VHT on bare metal? Any clear coat?
