What next!? Already have heads and cam...almost every other bolt on...
Just wondering what to do next!? I already have GTP Stg2 heads w/port matched intake mani,Hotcam Kit and pretty much every little bolt on known to man. So what next? I have about $600 right now I saved up. What do you guys think? I know nothings cheap...should I keep saving?
Re: What next!? Already have heads and cam...almost every other bolt on...
I know alot of people are afraid of it but its not that scary, use NOS. Get a little 100 shot like I am. You most likely will see 11's.
As mentioned above NOS is also another "step" but if you're still running on the stock rearend I'd advise to focus attention on that FIRST because with the mods you already have your rearend is pretty much a ticking timebomb and adding NOS will just be the straw that breaks the camel's back.
I would start putting money towards a rear end. It's an insurance policy and will save you a lot of time and sweat in the end.
Sorry guys, my bad!
- GM hotcam KIT
- GTP Stg 2 Heads
- Ported Intake Mani
- Holley AFPR
- Holley 52 mm TB
- New Opti
- MSD 6al w/ new coilpack
- JET HOT LT's
- No Cats
- SLP Exhaust
- FLP Electric Exhaust Cutout
- Walbro 255
- Racetronix 32lbs injectors
- Rear End Gurtle
- 3.73 Gears
- New Auburn Posi
- BMR panhard par
- BMR Lowering controll arms w/ relocation brackets
- BMR Boxed Subframes
- BMR Adjustable Torque Arm
- SLP Strut Tower Brace
- SLP Lvl2 springs
- Bilstien Shocks
- BMR Tunnel Brace
- 1le rear sway bar
- 1le Drive Shaft
- LT4 KM
- Speedinc Tune
- Manual Fan Switch
- Trans Go Shift Kit
- B&M trans cooler
- Vigalante 2800
And thats all I can think off the top of my head....If i can think of anything else I'll throw it on!
- GM hotcam KIT
- GTP Stg 2 Heads
- Holley AFPR
- Holley 52 mm TB
- New Opti
- JET HOT LT's
- No Cats
- SLP Exhaust
- Walbro 255
- Rear End Gurtle
- 3.73 Gears
- New Auburn Posi
- BMR panhard par
- SLP Lvl2 springs
- Bilstien Shocks
- BMR Tunnel Brace
- 1le rear sway bar
- 1le Drive Shaft
- LT4 KM
- Speedinc Tune
- Manual Fan Switch
- B&M trans cooler
- Vigalante 2800
Electric water Pump? Maybe a single plane conversion. I'm in the same boat and I'm trying to keep from going back into the motor for a cam swap.
. Plus I need another $300.00 Tune.
Yeah man I feel your pain, I would love to throw another cam in there, just I don't have the time to do it myself, and cost too much to have somebody else put it in
. Plus I need another $300.00 Tune.Those two mods right there will probably give you another 30 FWHP.
Would there be any clearance problems with 1.7 Rockers? I have LT4 Composite valve covers...if that even makes a difference.
Get more out of your setup.. the times are lackluster
