What next!? Already have heads and cam...almost every other bolt on...
Old Feb 20, 2006 | 10:10 PM
  #16
FastZinTennessee's Avatar
Re: What next!? Already have heads and cam...almost every other bolt on...
How about a higher stall? On my HOTcam'd car I felt like I was leaving some E.T. on the table with the 2800. I've seen nice times out of the Yank SS3600 You'd need to save up a little more though.
Edit: what's your 1/8th mile trap and E.T.? Your track times seem a little slow......
Old Feb 21, 2006 | 03:36 AM
  #17
BlackBird97's Avatar
Tell me about it, compared to other Hotcammed/ heads cars with the same type of mods...it juss seems to be doggin...and that time was with slicks!
1/8 on that run was 7.969 @ 86.13MPH....and that was the best I could ever pull outa it with the slicks!
Old Feb 21, 2006 | 05:50 AM
  #18
Guest47904's Avatar
Guest
Cams, converters and RE gears all work together. It's best to contact someone who knows rather than guess at the proper stall speed.
Old Feb 21, 2006 | 07:11 AM
  #19
Hmmmmm, I had a HOTcam kit, homeported heads, SLP headers, flowmaster catback, Meziere pump, K&N CAI, Midwest 2800 stall, PCMforless tune, drag radials and I ran a similar time.
The run was made at a notoriously slow 1/8th mile track in the area. My particular 1/8th mile times there lag about .3 and 1mph behind my times at Beech Bend which is a 1/4 mile. My best run was an 8.1 @86.7, and although I never made it to the 1/4, I was expecting a 7.80 @88 on the way to a 12.3/12.4 @110. I noticed that compared to other cars mine was a bit slower off the line, but seemed to start running cars with similar E.T.'s down at about the halfway point of the 1/8 mile track. This is what showed me that I needed some more stall.
Old Feb 21, 2006 | 09:59 AM
  #20
Stoopalini's Avatar
Detailed info on the Scorpion 1.7 swap can be found here:
http://camaross.com/forums/showthread.php?t=422491
They will clear the LT4 covers with no modification. But depending on the rest of your valvetrain setup, it might get expensive for ya (unless you already have guideplates, hardened pushrods, and spring that will handle the extra lift)
Thomas.
Old Feb 21, 2006 | 11:01 AM
  #21
teke184's Avatar
i'll second the 3 suggestions above...
the obvious bolt on is the electric wp.
or
more converter
or
1.7 rockers
maybe you'd pick up some top end if you fabbed up a 2.5" true dual exhaust setup?? or maybe just a second cutout on the ypipe with dual electric plates.
Old Feb 21, 2006 | 11:51 AM
  #22
WhyHelloOfficer's Avatar
I'd definately say electric waterpump -- other than that maybe some seat time?
Your 1/8th mile sounds good, perhaps the slicks are slowing you down on the top end? What size are they?
This past weekend I pulled a 12.7 @ 106 on my stock heads LT4 Hot Cam A4 car.
Old Feb 21, 2006 | 07:33 PM
  #23
Sorry I'm a bit tired...its been a long day...But whats seat time?
Old Feb 21, 2006 | 09:04 PM
  #24
Wckd94Z's Avatar
seat time=driving time. he means get better at driving the car
Old Feb 22, 2006 | 02:03 PM
  #25
Think a Tubular K-member would help any? Supposedly kills off 32lbs...?
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
