What needs to be plugged after AIR pump removal?
Old Apr 14, 2003 | 10:50 PM
Rich_z28's Avatar
Just like it says, what all needs to be plugged. Sizes would help too. I have the MAC headers BTW. I don't have a cat and am in the middle of an opti change so I figured this would be a great time to remove it.
Old Apr 14, 2003 | 11:01 PM
Buttercup's Avatar
Both headers AIR fittings need to be plugged and also the AIR pump feed off of the induction (the tube from the air pump to the intake behind the driver's side headlight).
I don't recall the exact sizes I used on my '95. There were two different sizes used based on the year but for some reason I can't remember which is which at the moment May want to do a search
burnemonm1's Avatar
I just did the same thing allI did was plug the whole in the intake tube and the holes in my headers and I also removed my cat and my egr and the car runs great!! btw how does that electric cut-out work... does it leak??
www.streetlethalperformance.com
Old Apr 14, 2003 | 11:03 PM
Rich_z28's Avatar
Don't you have to fab something up to block the EGR?
The cutout works great, but does leak a bit.
Old Apr 14, 2003 | 11:06 PM
Buttercup's Avatar
The EGR and AIR systems are completely different and not related. It's best to fabricate or buy some blockoff plates if you're removing the EGR as well. You may throw a code for removing the EGR if you don't reprogram the PCM
Old Apr 14, 2003 | 11:11 PM
Rich_z28's Avatar
No, I'm just taking the Air Pump off. Correct me if I'm wrong but the EGR goes to the little extension on the Passenger side header right? Just want to make sure we're on the same page.
Old Apr 14, 2003 | 11:18 PM
Buttercup's Avatar
Yes, the EGR is connected to one of the passenger side primaries with a flex pipe. Leave that connected. The AIR fittings are larger and threaded which sit on top. If in doubt just feel the pipe upwards, if it's corrugated and goes to the rear of the intake manifold, that's EGR.
Old Apr 14, 2003 | 11:21 PM
Rich_z28's Avatar
K thanks. You rawk Buttercup (sorry don't know your real name).
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CobraEatr
Jul 24, 2004 11:37 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
