What is my pinion angle?
I measured these measurements from the drivers side of the car.
The angle on the tq arm, on the mount on the rear end is a +0.5 (to the right of zero), and the angle on the DS is a +2.5 (to the right of zero)
.5-2.5 = -2
is -2 my pinion angle? Or is it +2?
.5-2.5 = -2
Re: What is my pinion angle?
The driveshaft and pinion shaft should form a \/ with the point towards the ground. As you have described it, appears thats what you have. The pinion shaft is pointed up +.5-deg, and the DS rises toward the front of the car at 2.5-deg.
You might have got more responses on the "Drivetrain" forum.
Aug 7, 2015 01:26 PM
kev93z28
Aug 19, 2002 12:48 AM
