What MPH would you expect?
I was wondering what mph you would expect with a cam like this with stock heads.
242/252
.592 with 1.5's
110lsa
For now it'd be on stock heads until I get some more money. With tuning I am wondering what I may be able to expect.
I have midlenghts right now but long tubes are on the way. Also have air foil, and cai. Thanks in advance.
242/252
.592 with 1.5's
110lsa
I can't remember the specs of the cc306 but some people have reached 115 with stock heads. That there is a very big cam, which will not perform very well until you get heads. I would say for you at least 108 mph probably a bit more though. Make sure you know what your getting, a big cam like that isn't real great on stock tuning or without gears/converter cause it needs to get up in is power range, otherwise it will be a dog. I forgot to read your profile so ignore my thoughts if you already have the right parts.
well I have already trapped 108.33 once with just my midlengths and ory. I dunno why my car traps pretty high for very little mods. I am thinking of going with a little bit smaller cam. It's 236/242 110lsa and I am waiting to here what the duration is.
That is a very high mph you've got, so a nice cam would really speed things up nicely. I would probably go with the smaller cam, the other one is better suited for a stroker, also that lift is very high. I can't remember but I think you'll be running into trouble with that much and 1.6 rocker arms. I would hate to see you bend some pushrods
Also the stock heads will need some serious porting to match those numbers, but I guess thats up to you.
NewsBot
Sep 14, 2015 09:20 AM
