What mods should I do now??
Old Dec 9, 2003 | 08:22 PM
bs15788's Avatar
I have my engine apart putting my lt4 cam in, and I was thinking about doing some other mods. Do you guys have any other ideas of what I should do while it's apart.
Old Dec 9, 2003 | 08:34 PM
drewstealth's Avatar
Well it really depends on what kind of money you have to spend. The best mod you could do is get you heads ported. But thats not gonna be cheap. You could also get an electric water pump while you at it.
Old Dec 9, 2003 | 09:13 PM
LT1ponykilla's Avatar
Im assuming you got the hotcam kit and are installing rr's and all. I would consider a bigger throttle body and some good tuning. My man above was right about the heads. Thats my next step on my car. Good luck.
Old Dec 10, 2003 | 03:18 PM
bs15788's Avatar
Any other suggestions.
Do you guys have any other suggestions for mods. Any input is helpful. thanx
Old Dec 10, 2003 | 04:55 PM
You could get a bigger tb, tuning, gears, and some goodies like that.
Old Dec 11, 2003 | 03:52 AM
QCKZ28's Avatar
if you have an auto you will need a 2800 stall/shift kit/tranny cooler
3.73 gears
electric water pump
do NOT get bbk headers, get something better
get rid of the hollowed cat, get an Off road pipe
cutout
computer tuning
52mm TB
port your heads
double roller timing chain
good time to replace your opti if its high mileage
dont forget drag radials.
jad
Old Dec 11, 2003 | 10:12 AM
Hey now, nothing wrong with BBK's.
Old Dec 11, 2003 | 11:25 AM
RedPhenx's Avatar
timing set, headers, water pump, and opti are probably a good idea to replace now rather than later
Old Dec 11, 2003 | 12:07 PM
suprchrged400's Avatar
I have BBK's and I like them but they did on a dyno shootout produce the LT1's max torque and HP about 400RPM's sooner than guys with Arizona speed and marine or SLP 1 3/4 headers BUT my power fell off 400rpms sooner than theirs too. For a stock motor, they work o.k. and keep me legal but if money was no issue I'd do Finish Line Performance with the included offroadpipes and high flow cats for 1200.
Old Dec 11, 2003 | 01:28 PM
besz28's Avatar
373 gears
Old Dec 11, 2003 | 01:49 PM
eagleknight97's Avatar
yeah, definetely do a better timing chain, new opti, if you got the money, port the heads, and the stall and tranny cooler. Good luck
Old Dec 11, 2003 | 10:02 PM
bs15788's Avatar
Thanks for the help guys, and I have the m6 tranny so I won't be doing any stall mods. If anyone else has any ideas throw them out here. I'll check this periodically to see if anyone else responds.
Old Dec 12, 2003 | 01:12 AM
QCKZ28's Avatar
M6 = 4.10 gears
jess
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
