What mods should I do next?
Old Aug 1, 2013 | 10:05 PM
Z28david0's Avatar
Hello everyone I wanted to see what would be your next
Mods with 5k if this was your car.I'm not sure how much more hp I can add on safely.here are my mods as far as I know.stock 350, it has a mild cam, ati 600b pro charger,PCM,dynod,crane ignition module and coil,36lb/hr fuel injectors,walbro fuel pump, and a adjustable fuel pressure regulator. Also need to replace pro charger belt to be safe, but i don't know what the specs are on belt and where to buy.
Old Aug 2, 2013 | 04:59 PM
parkers Z28's Avatar
Re: What mods should I do next?
What are you planning on doing with the car ?
Old Aug 2, 2013 | 05:47 PM
my94blackz's Avatar
Good heads.
Old Aug 2, 2013 | 09:52 PM
Z28david0's Avatar
I plan on just using the car as my daily driver.What would be a good set of heads for my setup? And how much power do you think it would add? Thanks for the replies!
Old Aug 9, 2013 | 10:22 AM
kylew707's Avatar
Good set of stock ported heads. Lloyd Elliott is the best bang for your buck in my opinion http://elliottsportworks.com/
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
