What Material To Use For Sealing Intake?
Old Jun 10, 2003 | 06:04 PM
Rico's Avatar
Just putting the intake back on, what's the best stuff to seal each end of the intake so It won't leak.
...Rich
Old Jun 10, 2003 | 07:01 PM
chasmanz28's Avatar
Re: What Material To Use For Sealing Intake?
...Rich
ultra copper rated for 700 degree's or the blue stuff rated for 600 same company makes it, i used the copper no leaks yet
Old Jun 10, 2003 | 07:03 PM
Rico's Avatar
Is this silicone or is it that gasket maker I think they call it.
...Rich
Old Jun 10, 2003 | 07:09 PM
...Rich
Copper looking tube. "Permatex Ultra Copper, sensor-safe, high temp RTV, silicone gasket maker".
chasmanz28's Avatar
...Rich
yes its permatex RTV sealant, i used the copper for the end rails and the blue for the gaskets
Rico's Avatar
OK THANKS
Old Jun 10, 2003 | 07:14 PM
Rico's Avatar
Do you have to put gasket stuff on the intake gaskets or is dry good.
I did it dry the last time and didn't have a problem
...Rich
Old Jun 10, 2003 | 07:16 PM
chasmanz28's Avatar
...Rich
i used a thin film of the blue stuff just to hold the gaskets together
Old Jun 10, 2003 | 07:17 PM
Rico's Avatar
ok thanks
Old Jun 10, 2003 | 07:25 PM
I only used sealer on the end rails (and up the side of the head about an inch. Nothing on the gasket.
Old Jun 10, 2003 | 07:31 PM
PatriotTA's Avatar
Any reason to use Copper over Black? They are both hi-temp and sensor safe.
Old Jun 10, 2003 | 07:34 PM
chasmanz28's Avatar
like i said before the copper is rated for 700 degree's and the back rail the egr tube tends to get that hot, really dont think 100 degree diffrence will do anything but if you have the abilty to buy the copper why not use it, JMO
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Apr 3, 2015 10:54 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
