What mark should the clutch fluid be at?
Old Jul 6, 2003 | 05:36 PM
PatriotTA's Avatar
On the clutch resorvior, it says to fill it to the step. When I remove the cap, you can barely see some fluid near the bottom of that rubber piece. If you take out the rubber piece, you can see that the fluid is at the level where the reservoir gets slightly larger in diameter. Is that the step mentioned on the cap? Or should it be filled to the top, just under the cap?
Old Jul 7, 2003 | 12:04 PM
PatriotTA's Avatar
Anyone help me out here??
TTT
Old Jul 7, 2003 | 01:39 PM
cals400ex's Avatar
i usually fill mine until the resevoir can't hold any more with the rubber piece in there.
Old Jul 7, 2003 | 02:33 PM
PatriotTA's Avatar
Sounds good to me. Anyone else??
Old Jul 7, 2003 | 03:01 PM
Hyperspeed97z28's Avatar
so the cap for the clutch, you can use brake fluid in? and fill it to the top ?
Old Jul 7, 2003 | 03:22 PM
PatriotTA's Avatar
Yeah, you're supposed to use DOT 3 brake fluid. About filling it to the top, I guess that's the general concensus so far.
Old Jul 7, 2003 | 11:51 PM
fbird95's Avatar
In my car no more fluid can fit with out over flowing, with the rubber peice in place.
sherwinZ28
Jun 6, 2015 08:48 PM
NewsBot
Apr 7, 2015 10:50 AM
HectorM52
Jan 30, 2015 11:08 PM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
