What mark should the clutch fluid be at?
On the clutch resorvior, it says to fill it to the step. When I remove the cap, you can barely see some fluid near the bottom of that rubber piece. If you take out the rubber piece, you can see that the fluid is at the level where the reservoir gets slightly larger in diameter. Is that the step mentioned on the cap? Or should it be filled to the top, just under the cap?
Originally posted by Hyperspeed97z28
so the cap for the clutch, you can use brake fluid in? and fill it to the top ?
NewsBot
Apr 7, 2015 10:50 AM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
