what lifters to buy?
Old May 11, 2004 | 03:21 PM
Mystic97Z's Avatar
when doing a head/cam swap,,well actually ported and polished heads,,what lifters should i get? is there an actuall "performance gain" from like comp ones, to new gm ones?
Old May 11, 2004 | 03:27 PM
madwolf's Avatar
Just get the Comp "R" ones. They're really nice, proven lifters. I beleive stock GM ones are rated to only about 6200-6300 RPM.
Lifters are a crucial valvetrain component. I'd buy the right ones if I were you.
- Comp "R" lifter owner.
PS. When I did the cam install some months ago, new GM lifters didn't cost SIGNIFICANTLY cheaper than the comp "R"'s, or at least not enough to justify buying them.
I remember seeing some good deals on ebay. Don't know if they still sell them there.
Old May 11, 2004 | 04:28 PM
95 Z/28 LT1's Avatar
Super Moderator
How much preload did you set them with?
Old May 11, 2004 | 04:39 PM
madwolf's Avatar
Don't remember... I did the lash the first time and I think I went 1/4 turn over. Then INTMD8 at Speed Inc did it the second time and I think he went 1/8 turn over... PM him directly, I'm sure he'll be happy to help.
Old May 11, 2004 | 04:45 PM
ibanez6rg's Avatar
I did 1/4 turn with mine. Anywhere from 1/4 - 1/2 is good.
Old May 11, 2004 | 06:52 PM
12SCNDZ's Avatar
COMP stock replacement lifters...Do they work? I run 12.0 @ 112 MPH and I shift at 6200 RPMs.
Frank
Old May 11, 2004 | 07:27 PM
rob97ss's Avatar
I just ordered a rotating assembly from combination motors and Seth said to go with stock replacement comp lifters,and he was having problems with the comp r's
Old May 11, 2004 | 07:42 PM
ibanez6rg's Avatar
That would probably be the 1st.
Old May 11, 2004 | 09:15 PM
my94blackz's Avatar
Advance special for me 140 bux
Old May 11, 2004 | 10:52 PM
Mystic97Z's Avatar
would these work? are these comp r's ?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
Old May 12, 2004 | 03:22 AM
madwolf's Avatar
Those are stock replacement lifters. Comp R lifters part number is:
875-16
Old May 12, 2004 | 06:18 AM
12SCNDZ's Avatar
There have been NUMERUS threads on here about people having problems with COMP "R"'s. I'm talking about reliability problems. As far as performance, I haven't seen any sustantial proof where they're any better than regular lifters.
So, my thoughts were...Why pay so much more for a lifter that isn't any better, and doesn't last as long?
Frank
Old May 12, 2004 | 07:34 AM
ibanez6rg's Avatar
Frank
What!? I've never seen one thread, until now. Did a search, too.
Old Jul 16, 2004 | 11:13 AM
CoUnTryMuZiCZ28's Avatar
Frank
Actually the Comp Rs are great... the throttle response with them is excellent aswell. Im buying a set now.. I had a collapsed Comp High energy lifter.. I havent read a thread that said anything bad about them....
Ibane6rg ... can you use them in a daily driver?
Old Jul 16, 2004 | 11:36 AM
pillagenburn's Avatar
would an AFR hydra-rev kit help in this situation? with higher revs that is - would it increase the longevity of the lifter?
peace
