what lifters?
what lifters?
I'll be upgrading to a bigger cam. RPM range of about 3000-6200(give or take). Will probably be using the Comp 918s. I already have Comp R lifters. I've had them in for a while and spun to 5900+ on the dyno, do I think they're alright. No valvetrain noise or anything. Would this situation justify spending $450-$500 on Morel lifters?
P.S. The cam I'm going with will most likely produce a similar dyno graph as the LE2 cam. Flatter torque curve..power just past 6000-6200. Just to give a better picture. Probably peak tq around 4500 or so. Peak power of 400-415(??) Thanks!
Do a search on the Comp R's. Alot of problems with them. When I did my LE2 setup I bought a new set of OEM lifters and have had no problems and I shift at 6300 rpms. I got them from Dal Shaughbaugh for right at 200.00. Good luck.
HVY SS
HVY SS
A recent post about lifters...http://64.65.63.61/forums/showthread...=1#post4403713
