what lifters?
Old Feb 9, 2007 | 10:41 PM
maro z28's Avatar
what lifters?
I'll be upgrading to a bigger cam. RPM range of about 3000-6200(give or take). Will probably be using the Comp 918s. I already have Comp R lifters. I've had them in for a while and spun to 5900+ on the dyno, do I think they're alright. No valvetrain noise or anything. Would this situation justify spending $450-$500 on Morel lifters?
P.S. The cam I'm going with will most likely produce a similar dyno graph as the LE2 cam. Flatter torque curve..power just past 6000-6200. Just to give a better picture. Probably peak tq around 4500 or so. Peak power of 400-415(??) Thanks!
Old Feb 9, 2007 | 10:58 PM
hvyss's Avatar
Do a search on the Comp R's. Alot of problems with them. When I did my LE2 setup I bought a new set of OEM lifters and have had no problems and I shift at 6300 rpms. I got them from Dal Shaughbaugh for right at 200.00. Good luck.
HVY SS
Old Feb 9, 2007 | 11:34 PM
A recent post about lifters...http://64.65.63.61/forums/showthread...=1#post4403713
Old Feb 10, 2007 | 04:05 AM
maro z28's Avatar
sweet..thanks alot shoebox.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
