What is the largest cam I can run with out throwing an SES light?
Old Dec 17, 2003 | 06:06 PM
pgriffith's Avatar
What are some of the big cams you guys have with no SES? I am in utah and we do OBD2 emissions testing here. We dont have to pass the sniffer anymore what they do is plug directly into the pcm and if there are no codes being thrown and the ses light is off then i can get it to pass. Is there any way i could run the CC306 in my 383 stroker with proper tuning and have no ses light? Or even possible the GM847 cam or something similiar? I want lots of power but I also want to pass emissions.
Please help.
Old Dec 17, 2003 | 06:29 PM
Spinner's Avatar
I'm going to assume your talking about an LT1 and not your 3.8 V6... lol
You can run a giant drag race solid tappet roller cam and not throw an SES light. Cam size and SES have nothing to do with each other.
Old Dec 17, 2003 | 07:12 PM
QCKZ28's Avatar
its all in the programming,
it has nothing to do with your cam.
jesse
Old Dec 17, 2003 | 11:19 PM
pgriffith's Avatar
Sorry if the sig was a little misleading. I havent updated it in a while. I am talking about a '97 LT1 i have swapped into my 98 camaro. PCM and everything is a 97. Can I get some more input on this topic?
What do you mean its all in the programming?
Does anybody here have some insight on exactly how OBD2 emissions testing works?
Old Dec 17, 2003 | 11:25 PM
95lt1&99ls1's Avatar
it checks the o2 sensors.
Old Dec 17, 2003 | 11:35 PM
pgriffith's Avatar
I know it checks more then that.
I know this much, it checks for DTC's, SES light, checks all emissions equipment and makes sure it is ready.
If i have a custom pcm programmed and say i have a certain code programmed out so i dont get the ses will the obd2 emissions testing catch this and fail me?
Old Dec 17, 2003 | 11:52 PM
turbo_Z's Avatar
yes it will. maybe you could get a shop to pass you as long as you can keep the emissions down but from what i understand the PCM is scanned for DTCs... anything that comes up emissions related will fail you.
the cam itself doesn generally set off the SES light. its all the mods like pulling out AIR/EGR that cause codes... and low cat efficiency possibly if you dont replace the rear O2s with sims. the cc306 or larger may cause the CPS sensor to think the motor is randomly misfiring too.
Old Dec 17, 2003 | 11:57 PM
SS MPSTR's Avatar
This is true. I've even heard it happening on stock displacement engines with the CC305 on 112* LSA with OBDII.
Old Dec 18, 2003 | 01:27 AM
96LT1TX's Avatar
In my 96 I have o2 simmulators on y-pipe, does that mean it just reads a stock looking reading or what? If so, this would be a good idea for your setup.
Gtpguy
Jan 26, 2015 04:50 PM
1775.Z28
Jan 11, 2015 10:51 AM
Queens94z28
Dec 20, 2014 09:11 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
