What kinda HP will these heads support? flow numbers inside
Old Mar 9, 2005 | 08:56 PM
Valkyn71's Avatar
These are LE1 heads, stock sized valves.
MAX CFM Avg CFM
185.0 132.6
263.0 190.1
Lift No. 1 No. 2
0.05 25.9 36.1
0.10 50.2 65.2
0.15 74.2 98.7
0.20 93.5 131.8
0.25 116.6 162.4
0.30 131.2 192.3
0.35 145.0 209.5
0.40 156.3 225.5
0.45 164.1 242.4
0.50 172.0 255.5
0.55 176.1 262.1
0.60 182.1 263.0
0.65 184.1 261.0
0.70 185.0 255.5
So what im curious is on stock cubes, how many HP do you think these heads could support?
Im running a Brett Bauer custom cam, similar to LE1
Old Mar 9, 2005 | 09:04 PM
jchevy's Avatar
Re: What kinda HP will these heads support? flow numbers inside
370-390 at the wheels with all the other bolt ons and a good tune.
Have you run this motor yet? How does it idle?
Old Mar 9, 2005 | 09:09 PM
Valkyn71's Avatar
Idles great, you can tell its not exactly stock tho
Cruises well also, about 1800rpms at 70
Old Mar 9, 2005 | 09:14 PM
jchevy's Avatar
Looking at the specs of the cam you would think it would have a nasty lope.
I will have a very similar setup as soon as i get the heads back from llyod. I was expectign them today, but they were a no show.
Whats your idle set at?
Old Mar 9, 2005 | 09:18 PM
Valkyn71's Avatar
950 or so i believe, whatever PCM4less thought would be best from looking at the specs of the cam.
parkers Z28
Mar 11, 2016 08:14 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
