what kinda of 383 shortblock for 200 n20
Old Oct 26, 2005 | 09:08 AM
QCKZ28's Avatar
the car will have 400rwhp NA with a 200 shot of nitrous, what am i looking at spending on a 383 or 355 shortblock?
i know i need all forged internals and 4 bolt mains. any recommended place to buy from?
thanks,
jesse
Old Oct 26, 2005 | 09:21 AM
cwaldt's Avatar
Re: what kinda of 383 shortblock for 200 n20
http://www.victoryracingengines.com/...TX&BLOCK=SHORT
Old Oct 26, 2005 | 09:23 AM
WS Sick's Avatar
Well you'll need to build it then to handle the full 600 (figured hp)
So, youre looking at full forged bottom end, stronger main caps , and put together with alot of attention to detail.
For oiling a HV is uneccesary, but constant even flow (reliably) is. So get a NEW High quality oil pump a good (deeper) pan (hold more oil, and keep it away from the reciprocating assembly).
An eagle forged crank, eagle Hs or some scat Hs should hold up to your goals, as for pistons, I'm partial to JE/SRPs. I would go 5.7 rod for insurance to keep the crown thick on the piston.
With alot of nitrous excessive compression isnt a must for power (static) so I would shoot for 10.5 to 11:1 to spray 200 shot on and keep it simple.
Do not skimp on the prep and assembly.
Old Oct 26, 2005 | 09:25 AM
GetaZforgetGT's Avatar
With a 200 shot you should use nitrous pistons and heavy duty pins. Nice thing about that is it give you the option to set up the engine to what ever spec you want not what the kits come as from a catalog.
I'm working with Erik @ Horse Power Engineering (HPE) for a very similar build.
Fully forged with nitrous pistons, heavy duty pins and fully assembled shortblock in the $3400 range after shipping but I'll be sending my core back also.
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Jul 31, 2015 08:15 AM
wesley81
Jul 27, 2015 11:31 AM
alphaauto
Jul 26, 2015 04:40 PM
