What kind of Guide Plates are you NSA guys running?
just out of curiosity, does anyone have a pic or two comparing the sbc or combination motorsport guideplates with the correct gm or aftermarket ones? I'm curious to see the difference.. I found a pic on shoebox's website showing the resultant rocker orientation:
http://shbox.com/1/guideplate_compare.jpg
but was interested in actual geometry comparisons..
I adjusted the Iskys to get the rollers centered front to back on the valvetips then tighten the stud, at which point the plate moves and you start over again
, is a PITA with everything oily and yes I think it would be a big headache in an f-body. I can actually get to my engine and it was not the most enjoyable project.
they are the only way to go, IMO.
The GMPP plates DO NOT result in perfect alignment, only "good enough", I tried Comp before them and that alignment was BAD some valvetips were not covered.
oldschool
Feb 9, 2016 09:21 PM
